After some tyre/410 transfer box input
  • macguyverjimny
16 Apr 2014 23:07 - 16 Apr 2014 23:10 #112388 by macguyverjimny
Replied by macguyverjimny on topic After some tyre/410 transfer box input
gaz3359 wrote: Hi all,im after a bit of input of anyone running a 410 transfer box,i know the subject has been covered alot but im pondering on what tyre size to go for at the moment.
ive just got a 410 box and props i need a couple other bits and then should be good for fitting it all in.
im thinking of going with 215 80 15 sahara's i currently run 195 80 15 sahara's and cant moan about the tyre and how well the jim performs on the lanes even in lardy sorry landy rutts.im just after a bit more clearance with out killing clutches and making the jimny worse to drive.
The other thought i had was i know richiesjimny was running 235 75 15 on a 410 box and a m16a fitted (ive also got an m16a fitted) and he said the combo was spot on for laning.
I'm only running a 2" suspension lift and i know with the 235's i need more clearnace so was thinking do i go for this size instead of the 215 80 and do an 1" body lift and a bit more arch trimming.i only really do green laning so want it to drive half decent,although i am concidering a couple of p+p days this year but not basing my decision on this.also before anyone says i cant afford a proper lobster box.any input much appreciated thanks
I know of a guy down here in south africa who ran 215 80 r15 on his vvt jimny with a 2" lift, personally if i would recommend 235's and a 3 inch,
When I look at a car it must be properly balanced.
Gearing,
Height,
Power,
Ect.
Im i am not mistaking, i think you did a engine swop?
Yes you have enough power for 235 then , most guys who run 235's have roll cages and go the 3 inch route and get their results they want.
Only reason i havent considered a body lift is because of the mounting of my aftermarket bumper,
At the moment my fuel consumption is so bad i wana go from 215 75's back to my set of 205 70's :) but i probabily will not...
Last edit: 16 Apr 2014 23:10 by macguyverjimny.
  • Rockwatt
17 Apr 2014 21:00 #112459 by Rockwatt
Replied by Rockwatt on topic After some tyre/410 transfer box input
Bigjim91 wrote: Like I sed rockwatt told me so ile find out to soon
i think you got muddled:-)
front jimny prop stays as it is , the rear prop is replaced with a front 413/samurai prop (not a 410/santana as they are 16mm to long)
the gearbox to transfer box short prop is replaced with with a samurai item
and if your fitting to a later pushbutton transfer box model the a custom gearbox to transfer prop would be needed but the gearing is wrong in the later gearboxes (strait through in 5th not 4th) so it would be advisable to change to an early gearbox as well.
  • gaz3359
17 Apr 2014 22:21 #112471 by gaz3359
Replied by gaz3359 on topic After some tyre/410 transfer box input
RichiesJimny wrote: Pajero's great I love it already, I've fitted new modulars with 33 inch tyres I just need to fit my long wheel base rear springs and adjust the front torsion bars and I'm done, it doesn't need anything else for green laning.
Are you keeping your Jimny now?
Keeping it for the time been rich once the box is in and iv decided on tyres that is it not spending anything eles on it.may change it next year.have to get out sometime soon once ive done me box ect will get someting arranged.
  • gaz3359
17 Apr 2014 22:31 #112472 by gaz3359
Thanks for evreyones input having a think and got a set of tyres to try when its in.
Time to create page: 0.530 seconds
