oil leaking out of transfer box
- daiwalmsley
18 Mar 2014 09:21 #108941
by daiwalmsley
oil leaking out of transfer box was created by daiwalmsley
new to the whole jimny thing, got oil leaking out of transfer box! new one or is it fix able
- idiotmobil
18 Mar 2014 09:38 #108942
by idiotmobil
Replied by idiotmobil on topic oil leaking out of transfer box
should just be new seal where about are you as I have a good transfer box I could do with getting rid of
- daiwalmsley
18 Mar 2014 10:13 #108945
by daiwalmsley
Replied by daiwalmsley on topic oil leaking out of transfer box
cheers is it easy job to change?
19 Mar 2014 06:53 #109063
by robs5230
standard jimny - for now
Replied by robs5230 on topic oil leaking out of transfer box
where on the box is the leak ? if it's around the front of the box / middle prop area it could be the gearbox oil seal
- daiwalmsley
19 Mar 2014 18:36 #109119
by daiwalmsley
correct right at front of box, bought new seals! fitting them tomorrow fingeres crossed
20 Mar 2014 07:33 #109220
by robs5230
the gearbox rear oil seal on mine was damaged by a rear gearbox mount collapsing slightly and allowing the rear of the gearbox to push across to one side. worth checking the gearbox mount while you're under it
Time to create page: 0.196 seconds
