Bent rear tow points
- jonesyba420
26 Feb 2014 13:56 - 26 Feb 2014 14:05 #106204
by jonesyba420
Replied by jonesyba420 on topic Bent rear tow points
i pulled a stuck 1 series bmw off a muddy field with the tie down points, was fine just went at it REALLY gently, no snatching and used a bridal between the 2 tie down points to spread the load abit.
yea ive seen those hooks but as Dave said there is nowhere to fit it without alot of work.
only one bolt on option really, a tow bar (which only seem to be rated to 1300kg max tow capacity, so not sure how one would handle a jimny stuck half up the doors in mud as it could potentially weigh 2-3-4 times as much).
for the front, ORA did (past tense as there not on their site anymore) bolt on front recovery points, or you can try get a suzuki one from japan at vast expense.
or make your own.
or make your own.
Last edit: 26 Feb 2014 14:05 by jonesyba420.
- Fyffe
26 Feb 2014 18:05 #106227
by Fyffe
Replied by Fyffe on topic Bent rear tow points
If i was to want to go ahead and get a tow bar would fitting now not be an issue with now not having the tin foil tie down eyes?
- Dave cc
26 Feb 2014 18:08 - 26 Feb 2014 18:19 #106228
by Dave cc
Replied by Dave cc on topic Bent rear tow points
Last edit: 26 Feb 2014 18:19 by Dave cc. Reason: photo added
- jonesyba420
26 Feb 2014 19:47 #106242
by jonesyba420
Could you fit them anywhere without moding anything?
- Jimny_Aus
26 Feb 2014 23:10 #106294
by Jimny_Aus
Replied by Jimny_Aus on topic Bent rear tow points
im going to make some up next weekend, RHS flat bar at one end and a eyelet, then bolt it through the chassis rail. im not fussed on the body work of my jim so ill be 'trimming' it to fit....
- hunter1084
26 Feb 2014 23:18 #106296
by hunter1084
I had some like these on my old jimny, just had holes drilled on the bottom of the towbar it worked a treat.
Replied by hunter1084 on topic Bent rear tow points
GuardianAngel wrote: I was thinking of getting these. They come in black as well but I fancy chrome
www.bits4vits.co.uk/store/recovery/warn-...chrome/prod_288.html
