Jimny cv help (20 spline)
  • Cindythejimny
19 Feb 2014 22:16 #105227 by Cindythejimny
Jimny cv help (20 spline) was created by Cindythejimny
I have recently busted my os cv on on my 51 plate jimny. I ordered a cv front micksgarage after reg checking with them and turns out the 19 spline cvs they sent don't fit as mine is 20. I thought I'd be thinking ahead and ordered two...... Doh. Hopefully they will take them back but I am struggling to find anywhere that sells the 20 spline for my sohc Spanish beaut. Can anyone please help as I'm at my wits end. Frustratingly in the same night in the workshop I was fitting my new ORA pan hard set to find that after fitting the rear that front pan hard they had packed two end with the same threads and not opposites, not a successful night in the garage!!! So cv help please!!!!!
19 Feb 2014 22:29 #105229 by j999pre
Replied by j999pre on topic Jimny cv help (20 spline)
You could ask for a complete cv and shaft from someone second hand as the diff end and hub end are the same on all so you wouldn't need to match your existing shaft.
Grey pick up Jimny
  • Cindythejimny
19 Feb 2014 22:44 #105231 by Cindythejimny
Replied by Cindythejimny on topic Jimny cv help (20 spline)
So based on that if I have the easier to source 19 spline cv's then I could try to source the 19 spline shaft and I'm good to go and this should make life easier in the future??
  • j44kck
20 Feb 2014 09:13 #105251 by j44kck
Replied by j44kck on topic Jimny cv help (20 spline)
20 splines are not easy to find. as said 19s available with ease.
but swapping the shaft is easiest if you intend to smash the internals on a few more
20 Feb 2014 10:48 #105257 by safari
Replied by safari on topic Jimny cv help (20 spline)
instead of the 19 splines i fitted the 29 splines cause both ends r like mine
if u worry u die if u dont worry u still die so why worry
  • Cindythejimny
20 Feb 2014 13:42 #105281 by Cindythejimny
Replied by Cindythejimny on topic Re:Jimny cv help (20 spline)
So my next challenge is to find a 19 spline shaft. Thanks for the help
Time to create page: 1.511 seconds
