Need an opinion about Jimny suspension!
  • Maze
18 Feb 2014 22:15 #105128 by Maze
I need an opinion about the suspension! (take off spring spacers)
I have spring spacers with 2" (50mm in the front and 45mm in the rear) but I'm thinking put the front springs in the rear of the Jimny and buy only 2 new front springs with +2,5” to compensate the front, because the standard front springs are 55mm higher than the rear standard springs. I don´t know if you sell only the front springs, but what are your opinion about my idea.
I just don't know if the standard front springs are stiffer than the rear springs.
Regards
Leonardo
  • idiotmobil
18 Feb 2014 22:18 #105130 by idiotmobil
Replied by idiotmobil on topic Need an opinion about Jimny suspension!
the spring in the front are different each side, the drivers side is longer so you would end up lopsided bad ideas ever cutting courners just need to buy a liftkit if lifting anything or it just doesnt work out right
  • TomDK
18 Feb 2014 22:51 #105133 by TomDK
Replied by TomDK on topic Need an opinion about Jimny suspension!
idiotmobil wrote: the spring in the front are different each side, the drivers side is longer so you would end up lopsided bad ideas ever cutting courners just need to buy a liftkit if lifting anything or it just doesnt work out right
Only on RHD Jimny's.
Maze is from portugal, so his Jimny is LHD, and front springs have same length :)
  • idiotmobil
18 Feb 2014 23:11 #105142 by idiotmobil
I still say go with propper lift all round some one had put vitara springs of some sort in mine trying to match it to work and it just didnt and come straight out
  • Jimny_Aus
19 Feb 2014 00:08 #105146 by Jimny_Aus
Replied by Jimny_Aus on topic Need an opinion about Jimny suspension!
i agree, dont be a tight ass and buy a kit, cutting corners with suspension not a good idea. and to be honest most people get a 2 inch but then they put coil spacers in after, just get the jim bits or ORA i think... 4" kit with arms you wont regret it, i wish i bit the bullet and got a full kit. now im saving for a full one and have to sell my 80mm kit...
just my 'opinion though' ;)
19 Feb 2014 07:00 #105147 by robs5230
Maze wrote: I need an opinion about the suspension! (take off spring spacers)
Regards
Leonardo
ahh you have the 1.5 diesel don't you ? if you state what you are trying to achieve, the answers may be a little better.
standard jimny - for now
Time to create page: 1.918 seconds
