new shocks don't fit 98 model
  • squarebore
07 Feb 2014 09:15 - 07 Feb 2014 09:16 #103744 by squarebore
new shocks don't fit 98 model was created by squarebore
Hi, I bought a set of standard shocks on ebay for my 98 Jimny and the rears don't fit. When fitting the rear shocks I discovered that both the metal and rubber bushes are too wide at the top and won't fit the mounting bracket. The bracket has a maximum space of 33mm. The OEM shock bushes are 32mm. The bushes supplied are 37mm.
I have asked the supplier but wondered if perhaps they may be for a later model. Any thoughts?
Cheers
Michael
Last edit: 07 Feb 2014 09:16 by squarebore. Reason: typo
07 Feb 2014 09:23 #103745 by mlines
This is common on a lot of after-market shocks (including the ones I sell)
You need to trim the bushes to size with a mini-hacksaw.
  • GuardianAngel
07 Feb 2014 10:06 #103748 by GuardianAngel
Replied by GuardianAngel on topic new shocks don't fit 98 model
I had the same issue with some Rough Country shocks for my 2002 J. Sent them back (Jimny Bits) and replaced them with Trail Master ones that did fit.
  • idiotmobil
07 Feb 2014 10:28 #103751 by idiotmobil
Replied by idiotmobil on topic new shocks don't fit 98 model
Same as mine
  • jonesyba420
07 Feb 2014 10:31 #103752 by jonesyba420
Replied by jonesyba420 on topic new shocks don't fit 98 model
its probably because the shocks arn't designed for the jimny so the bushes that procomp and rough country provide will be for the truck the shocks are actually for, whereas trailmaster's are for a jimny so have the right bushes.
07 Feb 2014 15:34 #103773 by robs5230
just fitted some of the rough country 2-3" lift rear shocks on mine. they did have to be trimmed approx 3mm for the top mount .but easily and quickly done. the bottom bushes went straight in the rear shock relocators. and they work a treat
standard jimny - for now
Time to create page: 1.797 seconds
