decat jimny and mot test
- 410shotgun
05 Feb 2014 20:26 - 05 Feb 2014 20:27 #103552
by 410shotgun
decat jimny and mot test was created by 410shotgun
I took the manifold cat off my jimny 2 or 3 months back when I fitted a new exhaust
took it for a mot test today and it passed
Last edit: 05 Feb 2014 20:27 by 410shotgun.
- Bazcam
05 Feb 2014 20:37 #103553
by Bazcam
Replied by Bazcam on topic decat jimny and mot test
Cool, that's good to hear.
One of our jimny's had an annoying rattle at the manifold, turned out
the cat had started falling to bits, big chunks of a honey comb type material
were rattling about when it was revved.
We chopped it in half and removed everything and welded it back up, with the
heat shield back on you'd never know.
Should be ok for the test then
- wombat
05 Feb 2014 21:14 #103557
by wombat
Replied by wombat on topic decat jimny and mot test
If a vehicle is fitted with a cat as standard and it has been removed,it should fail an mot test even if it still passes the emissions test
- 410shotgun
05 Feb 2014 21:19 #103558
by 410shotgun
Replied by 410shotgun on topic decat jimny and mot test
yes that is the case but tell me how the tester can tell
- wombat
05 Feb 2014 21:26 #103561
by wombat
You can only tell if the cat has been replaced with a straight bit of pipe . Ive seen several cats that have obviously been cut open then rewelded but as a tester cannot see inside the cat they cannot fail the car if it passes the emissions test
- 410shotgun
05 Feb 2014 21:30 #103562
by 410shotgun
all I did was take off the manifold and break up the cat and tip it out
no cutting or welding and refit it back on sounds and goes better
Time to create page: 0.156 seconds
