"2inch body lift"'1inch spring spacers'
  • Millzy
01 Feb 2014 11:30 #102829 by Millzy
:P hi there I was wondering if someone could help me out I have newly purchased a jimny the previous owner had a 3inch suspension lift put on it but like most people I want more haha so I was thinking a 2inch body lift and 1inch spring spacers I was wondering how hard this process would be as this car is also my daily driver ...and tell me what other thing may need to purchase to pull this off any help be great thanks
  • TomDK
01 Feb 2014 11:47 #102832 by TomDK
Replied by TomDK on topic "2inch body lift"'1inch spring spacers'
Why do you want this extra lift? It only raises COG and makes it worse round corners and also worse offroad.
I have a 4" ora suspension lift which I think is 1" too tall. Would have preferred a +3" lift now that I have driven with the +4".
  • idiotmobil
01 Feb 2014 12:23 - 01 Feb 2014 12:24 #102833 by idiotmobil
Replied by idiotmobil on topic "2inch body lift"'1inch spring spacers'
very true im very happy with my 3" lift the only way I will go higher is when I run bigger tyres (if I do) from 29inch to 31inch if I get any rubbing then ill just do a quick 1 inch body lift as articulation on mines ok, higher is not allways better just 1 inch makes so much different to the drive as your need different radious arms etc to correct the axles or it will get wosre to drive and higher cog and more articulating all add up to a intresting drive round couners etc allmost6 to the point of having to drive it so slow on the road its useless
Last edit: 01 Feb 2014 12:24 by idiotmobil.
01 Feb 2014 13:11 #102838 by robs5230
mmm.. i have a 3" lift and i don't think i'd want any more. you wont do it's road manners any favours by going higher.
standard jimny - for now
  • markyp2000
01 Feb 2014 13:21 #102842 by markyp2000
Replied by markyp2000 on topic "2inch body lift"'1inch spring spacers'
I had a 4.5" o r a lift and wanted more just because i could and mine handled well through the back lanes it did lean a bet lol but it kept you wide awake in the mornings
  • Millzy
02 Feb 2014 00:28 #102988 by Millzy
Replied by Millzy on topic "2inch body lift"'1inch spring spacers'
Ok so maybe bigger tyres is an option I'm sitting on 28s ATM but obviously I'm gonna sacravice power and I'm a bit worried if do go taller about rubbing on guards anyone had any problems with bigger tyres ???
Time to create page: 2.933 seconds
