Petrol pipe sizes.
  • elgringo
24 Jan 2014 20:21 - 24 Jan 2014 20:23 #101889 by elgringo
Replied by elgringo on topic Went to the beach this morning
Cheers Kirkynut.
Well, I had a good look at the pipes today and they were only the 6mm return and vent lines.
They have now been replaced.
Now the O/S kingpin is leaking, so, parts ordered and I'll hopefully get around to that on Wednesday if the parts are with me by then.
Thanks again to all.
Last edit: 24 Jan 2014 20:23 by elgringo.
  • GuardianAngel
24 Jan 2014 20:24 #101890 by GuardianAngel
Replied by GuardianAngel on topic Went to the beach this morning
elgringo wrote: Cheers Kirky.
Did you replace all the pipes front to back? Did you use plastic or metal pipes?
I am probably going to do all the fuel lines (and brake pipes).
  • 410shotgun
24 Jan 2014 20:33 - 24 Jan 2014 20:42 #101891 by 410shotgun
Replied by 410shotgun on topic Went to the beach this morning
put nylon petrol pipes on
you can get all the pipe off ebay
around £1.30 a meter
Last edit: 24 Jan 2014 20:42 by 410shotgun.
  • elgringo
24 Jan 2014 21:39 #101900 by elgringo
I used 1/4 inch copper pipe as kindly informed by facade.
As it was only the two 6mm pipes, I only replaced from the tank down pipes to above the rear chassis cross member, the rest of the pipes were in really good condition.
25 Jan 2014 08:36 - 25 Jan 2014 08:43 #101935 by facade
Mine actually rusted at the chassis clip under the drivers feet, the corrosion started behind it.
The return pipe pinholed, and I started to get 25 MPG before I found what it was.
So I replaced just the front 12" of return pipe.
That lasted 3 years, then at the last MOT the brake pipes above the rear axle were corroded, so I changed everything. (He did suggest sanding them and painting if they weren't pitted, but I did that 3 years ago :whistle: )
Took 2 afternoons to do in copper, 1 to get the pipes off, as I wanted the clips I had to cut the pipes gently into sections and take the clips off with the pipes on (they just prise off a stud sticking out) I broke 3 :angry: I couldn't just slide them out as I had cleverly undersealed them.
The supply pipe actually snapped in half at the corrosion beneath the drivers feet when I was disconnecting it :ohmy: so it needed doing, but the corrosion wasnt as bad as it looked near the tank.
Last edit: 25 Jan 2014 08:43 by facade.
The following user(s) said Thank You: GuardianAngel
Time to create page: 0.159 seconds
