Jimny ECU brain fart?
  • Fyffe
18 Dec 2013 23:33 #96753 by Fyffe
Jimny ECU brain fart? was created by Fyffe
Hello,
the following fault has now happened to me twice now. engine temp is fine, fuel level fine ect....
occasionally when rolling down a road the jimny decided to kill its self under load, doesn't die completely but drops in revs down to idle speed then shoots back up and so on. i pull over to the side of the road, let it idle for a while rest RPM sounds normal but rev counter bounces between idle a 5k rpm.
i turn the ignition off. then problem solved drives away fine with now complaints?
any ideas gents?
  • jonesyba420
19 Dec 2013 04:54 #96756 by jonesyba420
Replied by jonesyba420 on topic Jimny ECU brain fart?
Sounds like crank shaft sensor to me,pleanty of info on here hit up the search button or google.
  • Fyffe
20 Dec 2013 13:10 #96932 by Fyffe
Replied by Fyffe on topic Jimny ECU brain fart?
yeh had a look into the crank sensor it seems to be that cheers for that lad
Jack
Time to create page: 0.318 seconds
