jeep 2.5td in the jimny
- adamjimny
07 Nov 2013 22:51 - 07 Nov 2013 22:52 #89908
by adamjimny
Replied by adamjimny on topic Re:jeep 2.5td in the jimny
Done number crunching and it'll work really well. Very well actually ha
What's the low range on a yota box?
Sent from my Z1 using Tapatalk
Last edit: 07 Nov 2013 22:52 by adamjimny.
08 Nov 2013 09:14 #89931
by Obarno
Replied by Obarno on topic Re:jeep 2.5td in the jimny
Just something else to consider adamjimny is that the Jeep front axle has the diff on the nearside, whereas of course the Jimny is on the offside.
Maybe you could use the Jeep transfer box then everything would work, assuming of course there is sufficient room for it. Teraflex in the States make a 4:1 conversion for the Jeep NP 231 transfer box. The NP 231 has a high ratio of 1:1 and a low of 2.72 in std form.
- adamjimny
08 Nov 2013 16:11 #89951
by adamjimny
Replied by adamjimny on topic jeep 2.5td in the jimny
yeah currently run a 5.1 and wouldn't want to go back higher again and as for diff on opposite side is no problem as brackets will need welding on so ill flip the axle casing at the same time. easy to do.
i want to keep my 5.1 low range or go lower but not higher
already knew Jeep ratio too cheers just not sure on the Toyota ratio
Time to create page: 0.141 seconds
