Engine managent light on - way to turn off?
  • littlegreenjimny
31 Oct 2013 20:05 #88803 by littlegreenjimny
Engine managent light on - way to turn off? was created by littlegreenjimny
Friends got a 2000 chain driven engine jimny
Engine management light came on, is there a way to reset this without diagnostic machine? Undo the battery for an hour?
Thanks
31 Oct 2013 20:10 - 31 Oct 2013 20:12 #88806 by Rhinoman
It will go off after you've disconnected the battery but will keep coming on again until you fix the problem. Whatever you do don't disconnect or reconnect the battery with the ignition on - thats a good way to blow the immo.
Last edit: 31 Oct 2013 20:12 by Rhinoman.
  • littlegreenjimny
31 Oct 2013 22:24 #88835 by littlegreenjimny
Replied by littlegreenjimny on topic Engine managent light on - way to turn off?
Cheers
Will try it and see if it comes back on!
01 Nov 2013 08:37 #88859 by facade
A diagnostic reader for the chain driven engine is only £20, or £5 if you have a laptop to connect it to.
Most likely cause is the exhaust gas sensor on the manifold.
Time to create page: 1.393 seconds
