Tow-bar elec socket wiring
- Thank you received: 360
31 Oct 2013 16:27 #88747
by Halford
Tow-bar elec socket wiring was created by Halford
started wiring up my tow-bar socket today but got stuck and downed tools until I can get good advice as I don't know what I'm doing :blush:
got the first bit OK
but here's where I stumbled, the socket has seperate wires brown (right light) and black (left light) and I'm guessing that both these socket wires connect to the single car harness wire as below:
Side lights
and I also assume the earth connects as below:
if someone can double check and confirm the above is OK (or wrong) I'd be very grateful
thanks
Halford
function | socket | Car harness |
Left indicator | yellow | Green/Red stripe |
Right indicator | green | Green/Yellow stripe |
Brake lights | red | Green / White stripe + dots |
Side lights
Right Light | brown | Red / Yellow stripe |
Left Light | black | Red / Yellow stripe |
earth | white | black |
thanks
Halford
31 Oct 2013 17:05 #88752
by gilburton
Replied by gilburton on topic Tow-bar elec socket wiring
if there is only one red/yellow wire feeding both rear lights then yes connect them together but if there are 2 find out which one goes where and connect them to the brown or black as appropriate.
The Earth is correct Black to white socket.
The idea of separate wires is you will still have one working tail light if one blows.
The following user(s) said Thank You: Halford
31 Oct 2013 17:13 #88753
by Halford
Replied by Halford on topic Tow-bar elec socket wiring
many thanks Gilbert
will take it all to bits again tomorrow :S
31 Oct 2013 17:32 - 31 Oct 2013 17:37 #88755
by gilburton
You don't have to use the car earth wire(black)
You can take the white wire from the socket and earth it anywhere on the car using an existing bolt or hole.
Just make sure you get a good earth and use a star washer to bite through the paint.
If you have reassembled it all and put the seats etc. back you could cheat and run a couple of wires from the rear light units and splice in to the tow bar wires at a suitable point?
I did something similar on my first Jimny.
Last edit: 31 Oct 2013 17:37 by gilburton.
31 Oct 2013 18:46 #88772
by Busta
Replied by Busta on topic Tow-bar elec socket wiring
When I wired mine up using the guide from this site, I found a couple of the wires were wrong/different. I didn't write down which though
Anyway, you may find you have to play around a bit to get the right ones.
31 Oct 2013 18:52 #88775
Replied by helijohn on topic Tow-bar elec socket wiring
Where physically are you tapping into the car wiring to do this please?
Time to create page: 1.954 seconds
