steering wheel and car shake when braking
- tae4551
21 Oct 2013 09:24 #87315
by tae4551
steering wheel and car shake when braking was created by tae4551
Hi Guys
new to the forum and have done quite abit of reading on my problem. still confused
I bought an 2008 model jimny yesterday. When braking a speeds above 70km the car and steering wheel shake rather violently. a speeds below 70km there is no issue. I thought it would be the rotors so i had them machined and new pads fitted. I took it out to highway to test. same problem. it only seems to happen when lightly braking at speed although I havent slammed on the brakes yet.
I jacked her up and gave every wheel a good shake. i didnt get any play out of any of them. I am not sure where to look next. stock standard setup. Any advice would be great
Thank you
Thank you
- markyp2000
21 Oct 2013 12:26 #87336
by markyp2000
Replied by markyp2000 on topic steering wheel and car shake when braking
By rotors you mean discs?
The calipers sliders may be rusted up disc may not be sitting on the hub correctly
I had discs skimed/machined and thay still give problems id fit new discs to be 100%
Or it could be a track rod end or king pin bearing is there and play when holding the wheel at 6 & 12 oclock and wobbling it also jack it up so the wheel is a few inches of the ground and put a bar under the tyre and lift it up a little and see if there os any up and down movment
- tae4551
23 Oct 2013 21:48 #87663
by tae4551
Replied by tae4551 on topic steering wheel and car shake when braking
thanks for the reply.
no the calipers are rust free. everything seems normal.
I took it for a long drive and it only shakes through the steering wheel between 70 and 80km and only when riding them slightly to the point it's very dangerous. if apply abit more force and usually just returns to a thump in the peddle and i can feel it through the peddle most of the time when braking at any speed. I will put new discs on it because I believe it is brake related and go from there.
thanks once again
thanks once again
- Stevo200
28 Jan 2020 00:52 #217755
by Stevo200
Replied by Stevo200 on topic steering wheel and car shake when braking
Hi mate, did you find a solution to the issue? I'm having the exact same problem, rotors were going to be my first stop. Speeds of 75-90 excessive shake when braking but fine at lower speeds. 2015 model completely standard.
Cheers.
Cheers.
- Thank you received: 1999
28 Jan 2020 05:01 #217756
Replied by Lambert on topic steering wheel and car shake when braking
I'm going to assume you mean 75 to 90 kmh not miles. Is the wheel vibration accompanied by a pulsing sensation in the brake pedal?
28 Jan 2020 06:25 - 28 Jan 2020 06:56 #217758
Replied by yakuza on topic steering wheel and car shake when braking
Mine had/has the same to some extent. Was much worse before I changed the brake discs. The caliper slider bolts can be kind of stuck with rust or grime inside and you cannot see this without dismantling. Mine probably have this now as I have changed to ventilated Jimny diesel discs and vitara calipers.
The problem can also be small and be worsened by the sum of all slack in the suspension like steering rack, king pin bolts and so on. you can read all about it in the wobble thread.
Last edit: 28 Jan 2020 06:56 by yakuza.
Time to create page: 1.216 seconds
