Sammi rear diff
- Dave cc
07 Oct 2013 16:44 #85409
by Dave cc
Replied by Dave cc on topic Sammi rear diff
so how do you get it up front ? cut and shut the mounts onto a Sammi axle case ?
- vitara_mad
07 Oct 2013 18:06 #85420
by vitara_mad
yes I would say that's the only way if you want Sammy diffs on the jimny be nice with 5.125 vit r&p
Replied by vitara_mad on topic Sammi rear diff
Dave cc wrote: so how do you get it up front ? cut and shut the mounts onto a Sammi axle case ?
- Dave cc
07 Oct 2013 18:13 #85421
by Dave cc
wouldnt be so hard re bracket it and maybe 3 link it in the process i guess
- vitara_mad
07 Oct 2013 18:17 #85422
by vitara_mad
I think your the man for the job so keep us updated
- Dave cc
07 Oct 2013 18:34 #85424
by Dave cc
Seen a relatively simple way to 3 link after working on Nick Andersons challenge truck fitting his new front brakes 2 links on 1 side one on the other hence not having the problem of the 3rd link getting in the way of the sump seems to work damn well in this set up just got me thinking
Just the price of the currie joints is killing it and not sure if rod ends would be up to it i know Rockwatt has got some joints on his facebook page but not seen anymore about them
- Rockwatt
07 Oct 2013 20:24 #85440
by Rockwatt
Replied by Rockwatt on topic Sammi rear diff
The problem at the front is the fact its high pinion to accommodate the steering link bar that goes behind the axle. If you wanted to go low pin then you would have to move the steering infront of the axle. And if your going to do that you may as well fit the Sammy swivels so you can use bigger cv's.
Dave cc the joints you have seen are not a Johnny joint replacement they are a uniball for ifs outer steering knuckles ! And they are more expensive than johnny joints
