jimny coolant loss
  • jbs215
05 Oct 2013 12:19 #85234 by jbs215
jimny coolant loss was created by jbs215
I have quite a bad collant loss at the moment, it on a sohc version.
I replaced several coolant hoses and also the metal coolant pipe and o-ring that come out the back of the water pump.
These were leaking before but are bone dry now.
Water pump gasket renewed and Thermostat gasket.
Not I have come to the conclusion that there were lots of leaks.
Are there any core plugs on this side of the engine (intake side)
Could it be head gasket or a cracked block.
Only leaks under pressure.
Thanks
  • idiotmobil
05 Oct 2013 14:25 #85243 by idiotmobil
Replied by idiotmobil on topic jimny coolant loss
I had the same problem and it was down to the plate on the back of the head held on by 2 10mm bolts theres a o ring in there that was gone on mine feel around the back of head the plate is about 4inch across removed that drain coolent first replace oring and I bet it fixes the problem toke me ages to find the problem till some one told me were to look
05 Oct 2013 15:28 #85244 by gilburton
Replied by gilburton on topic jimny coolant loss
Unless you can find an obvious leak it would be easier to get a pressure test done.
It's quite simple and should only take a few minutes to get checked.
They just put a pump on your radiator cap listen/look for leaks.
I don't know if any of the fast fit places do it but you could ask around locally?? Saves you lots of frustration especially if the leak is internal :)
I started off high and worked my way down ever since :-)
  • idiotmobil
05 Oct 2013 15:34 #85245 by idiotmobil
i would put money on the o ring
  • jbs215
05 Oct 2013 16:06 #85247 by jbs215
Replied by jbs215 on topic jimny coolant loss
Thanks for the replies.
I have pressure tested it a few times and can't track down where it is coming from.
Sorry to say but I have just been and pressure tested again and the plate at the rear isn't leaking.
Good tip though I didn't know about the o-ring at the back.
It seems to be coming from in between the front cylinders on the intake side.
  • idiotmobil
05 Oct 2013 16:47 #85249 by idiotmobil
mine didnt leek all the time some times it would be fine then some times it wouldnt i tryed every thing even checked the plate on back for leaks and didnt find any but toke the plate of any way and the oring was knackerd havnt lost a ml of coolent since
Time to create page: 0.900 seconds
