Running very rough - is a sensor the culprit?
- Jimnyash
14 Sep 2013 14:10 #83135
by Jimnyash
Replied by Jimnyash on topic Running very rough - is a sensor the culprit?
It's not mine on this occasion.
It's a S Reg 1998 model in question.
14 Sep 2013 19:28 #83173
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Running very rough - is a sensor the culprit?
OK so a g13b
Have you tried cam sensor? Is it a hard top? Try the orange screw in filter thing on the fuel rail. Clean it out with some brake cleaner this has worked before. I have a full manifold complete if you need sensors.
Grey pick up Jimny
14 Sep 2013 20:31 #83176
by facade
Replied by facade on topic Running very rough - is a sensor the culprit?
At that age you cannot read live data without the Rhinopower interface, or the official suzuki one.
There won't be a crank sensor, just a cam one, this will not throw up a fault if it fails, but the rev counter will jump around when missfiring.
Could be a sticking egr valve, but I'd have thought that it would put the management light on.
The PCV valve in the rubber hose between the rocker cover and inlet manifold has been known to cause idle problems, but shouldn't stop it going at speed.
- Jimnyash
15 Sep 2013 05:25 #83194
by Jimnyash
Thanks guys.
More things to try. Will see how it goes.
- Petecy
15 Sep 2013 06:40 #83198
by Petecy
Replied by Petecy on topic Running very rough - is a sensor the culprit?
Had the same problem solved easily. Carb cleaner spray, do lift the carb up from its mounts ( 4 nuts) and spray it well throughout. use a clean rag and wipe it. If the gasket is torn replace it, very important. 15 mins job.
This is a common minor fault , let me know how you get on.
- Jimnyash
15 Sep 2013 07:37 #83206
by Jimnyash
There's no carb. It's FI.
Time to create page: 3.820 seconds
