lock lobster fitted noisey and a vibration
  • TomDK
04 Sep 2013 21:33 #82204 by TomDK
Replied by TomDK on topic lock lobster fitted noisey and a vibration
idiotmobil wrote: fitted rocklobster today are they really winey as mine is like a car in reverse do they quiten down, also now have a bad vibration i never had before i think it mite possibley be were i had to the the rear coupling on the diff to fit the shaft all the other bolted straight on would being slightly out on my holes make this happen i kind of know the answer to this but wanted to know if any one else has done the same, also how do you remove the couple from the rear diff does the big nut just undo and it pull of with puller i tryed this but as i didnt know didnt want to pull it to hard if it was condected in diff some how
Many rocklobsters make more noise than the standard Jimny t-box. This because they are usually made of welded used SJ410/413 gears.
  • Rodden87
04 Sep 2013 21:37 #82207 by Rodden87
Replied by Rodden87 on topic lock lobster fitted noisey and a vibration
Wow mine is nothing like that at all! Mine is definatly wining but no we're near that bad! What speed are you doing when it's that bad?
  • idiotmobil
04 Sep 2013 22:06 #82216 by idiotmobil
Replied by idiotmobil on topic lock lobster fitted noisey and a vibration
its been built for me new seams to wine all the way through the speed range didnt seem to be that badd in 4 wheel drive but i mite have just not noticed
  • Paul4x4
05 Sep 2013 13:04 #82260 by Paul4x4
Replied by Paul4x4 on topic lock lobster fitted noisey and a vibration
You get what you pay for! Cheapish price comes with some whine... ;)
Welded gears are always whiny, and even a stock SJ box is considerably noisier than a Jimny's box which is pretty much silent. I have 6.5 Trail gear reduction gears, and those whine some too, but it's almost silent compared to some welded gears I've seen/heard, and it mostly whines just when I engine brake in small gears.
Get some billet cut gears if you don't like the noise, because it's pretty much there to stay!
  • idiotmobil
05 Sep 2013 13:40 #82261 by idiotmobil
I think it is worse on engine braking drove it to work this morning and its not to bad just a lot worse than im used to mainly used offroad so wont notice wile having fun found the vibration reason shafts not straight have to redo that properly can the coupling on diff just be pulled off
Time to create page: 0.142 seconds
