Removed the Catalytic Converter
- ClintZA
23 Aug 2013 13:24 #80812
by ClintZA
Removed the Catalytic Converter was created by ClintZA
Hi everyone,
Im from South Africa and we have problems with fuel quality which regularly blocks the Cat Converter.
so we removed it and i was wondering if anyone can suggest if there need to be additional fuel/air flow setting that should be changed to compensate for this mod??
23 Aug 2013 16:22 #80833
by facade
Replied by facade on topic Removed the Catalytic Converter
Don't think so, but if you have a late model, with 2 oxygen sensors, one each side of the catalyst, then the engine warning light will come on, because it knows the catalyst is not working.
There must be a way to stop this.
23 Aug 2013 20:12 #80865
by Rhinoman
Replied by Rhinoman on topic Removed the Catalytic Converter
You can add a spacer under the rear O2 to move it up out of the exhaust stream.
24 Aug 2013 10:28 #80895
by kirkynut
Replied by kirkynut on topic Removed the Catalytic Converter
But what about the planet man??? And the ozone layer???
Only joking! I don't think you'll end the world as we know it on your own!
- ClintZA
29 Aug 2013 05:55 #81390
by ClintZA
Replied by ClintZA on topic Removed the Catalytic Converter
We earthed the engine management sensors to bypas the warning lights....
- ClintZA
29 Aug 2013 05:57 #81391
by ClintZA
I thought about the plannet and the ozone for a bit.........but that was when i traded my old Merc 450SL V8 for a Jim....i think i get a free pass on this:)
Time to create page: 1.508 seconds
