Brake woes
  • markyp2000
23 Jul 2013 17:03 #78002 by markyp2000
Replied by markyp2000 on topic Brake woes
So what did you do to the brakes yesterday
  • helijohn
23 Jul 2013 19:26 #78015 by helijohn
Replied by helijohn on topic Brake woes
markyp2000 wrote: So what did you do to the brakes yesterday
Bled the left wheel then the right wheel (at the balancer innit). Didn't see any air come out. :ohmy: Tried swapping drums and there seemed to be no difference. Checked the operating arm was as far back as it would go. The heat was getting to me so I reset the clearance on the drums, stuffed the wheels on and called it a day.
  • markyp2000
23 Jul 2013 23:19 #78039 by markyp2000
Does your car have abs as most jimnys only have one blead nipple on the rear on passengers side
  • helijohn
23 Jul 2013 23:49 #78041 by helijohn
markyp2000 wrote: Does your car have abs
No.
Mine has a bleed nipple on the N/S/ Cylinder and one that services the O/S Cylinder located at the load compensating valve which was pointed out by the tester as just about not working until I bled it.
  • markyp2000
24 Jul 2013 01:27 #78042 by markyp2000
The one on the load compensating valve is just to blead the valve both rear brakes are blead out from the nearside as the pipe goes in and out the offside then to the near side
24 Jul 2013 05:56 #78044 by facade
Replied by facade on topic Brake woes
I'm fairly sure the nipple on the compensator valve bleeds the front circuit ;)
Time to create page: 0.408 seconds
