Jimny rear disc conversion
  • Dave cc
04 Aug 2013 16:10 #78963 by Dave cc
Replied by Dave cc on topic Jimny rear disc conversion
bluejimny wrote: i believe Dave from bits4vits had the same callipers on his vitara, and he swapped back to drums due to problems with the callipers
Maybe Rover calipers have changed then :( my SJ has Rover 600s on the rear and been on there over 12 years never had a problem although are are only used on the fiddles.
understand what you are saying about handbrake Mechanisms but if you have it on the caliper does allow you make fiddle brakes as well and you geta poor mans locking diff thrown in for good measure
  • markyp2000
04 Aug 2013 16:31 #78966 by markyp2000
Replied by markyp2000 on topic Jimny rear disc conversion
I use rover 200/25 rear caliperas in mine and have no problem with them sticking but it is a sh*t kit the back plate could be made alot better
  • Dave cc
04 Aug 2013 16:43 #78972 by Dave cc
markyp2000 wrote: I use rover 200/25 rear caliperas in mine and have no problem with them sticking but it is a sh*t kit the back plate could be made alot better
Thing is its a mechanism on the handbrake and yes it does need maintaining but then it cant be anything compared to the rebuilding leaking cylinders and the worn out brakes shoes that jimnys suffer from and Tbh you cant exspect someone to convert to rear disc and ohhhhhhhhhh by the way you now need a X brake
Is a shame and i think Mark will confirm this that you cant have a hydraulic handbrake :( that would be the answer with the right set up you would get fiddles as well :)
04 Aug 2013 17:28 #78976 by jimkyx
Replied by jimkyx on topic Jimny rear disc conversion
maverick wrote:
Dave cc wrote: Found the Muddyzook kit looks like a bit of bent plate and some bolts for £170 delivered :dry:
Is it any good or is there better out there ?????
Here's the place to get them from www.rsmfg.co.uk/page21.html
Has anybody used items from RS Manufacturing ?
  • markyp2000
04 Aug 2013 17:34 #78978 by markyp2000
U Cant have a hydraulic handbrake for the mot unless you have a cable override
  • Dave cc
04 Aug 2013 18:38 #78991 by Dave cc
Apparently very hard to contact so ive read but they do a properly engineered solution
Time to create page: 1.407 seconds
