water leak, possibly cracked head?
- davies
10 Jun 2013 11:06 #73382
by davies
water leak, possibly cracked head? was created by davies
Hi there I have a 2001 jimny and it appears I have a water leak as my radiator needs topping up almost daily and the engine seems to be getting hot sometimes. I have a browny coloured gunk under the rad cap and am worried I could have a cracked head? The dipstick does not have any mis colour. If this is the case with a cracked head I am tempted to use seal up, is this a good idea? And it says on the instructions of use I would need to drain and flush the system, how do I do this? Any help or info much appreciated, many thanks, Michael
- markyp2000
10 Jun 2013 12:22 #73394
by markyp2000
Replied by markyp2000 on topic water leak, possibly cracked head?
Could be head gasket
- davies
11 Jun 2013 09:31 #73482
by davies
Replied by davies on topic water leak, possibly cracked head?
Thanks, I have just found out from my mechanic that it is a gasket leak. I am going to try chemi weld as its too expensive for me to fix, would you recommend this?
11 Jun 2013 16:37 #73505
by j999pre
Grey pick up Jimny
Replied by j999pre on topic water leak, possibly cracked head?
Nope. I don't believe in short cuts or miracle cures.
Which engine is yours? Twin cam?
Grey pick up Jimny
- UKDAN
11 Jun 2013 21:30 #73526
by UKDAN
Agreed if its head gasket only fix is head skim, reseat valves etc & new gasket, temp fix will only cause you more more work & expense later.
Replied by UKDAN on topic water leak, possibly cracked head?
j999pre wrote: Nope. I don't believe in short cuts or miracle cures.
Time to create page: 0.629 seconds
