Transfer box oil seal leak?
- GuardianAngel
14 Apr 2013 22:28 - 14 Apr 2013 22:37 #68717
by GuardianAngel
Transfer box oil seal leak? was created by GuardianAngel
I was under the J today and noticed a feint line of oil going across the under side of the floor pan right above where the prop bolts onto the transfer box output.
Looking closer I noticed a small amount of oil on the flange (or whatever the correct term is) which is being flung around when driving. It's only a small amount though. Hopefully you can make it out on the photo below.
m.flickr.com/photos/93589760@N06/8650361234/
So my question is, is this a failed oil seal? Would that allow oil to run through the output shaft and out where the prop bolts on?
If it is, do I need to take out the transfer box or can I change the seal in situ?
Last edit: 14 Apr 2013 22:37 by GuardianAngel.
14 Apr 2013 22:53 - 14 Apr 2013 22:56 #68719
by facade
The oil seal is on the outside of the flange, any leak would dribble out between the aluminium housing and the rusty part of the flange to the left of where your oil is.
You may find that the nut inside the flange has come undone and the flange is loose on the splined shaft, or the oil is somehow coming from the CV joint to the right.
Edit: Pictures don't work yet
Just undo the 4 bolts and lower the propshaft down and see what happens
Replied by facade on topic Transfer box oil seal leak?
Last edit: 14 Apr 2013 22:56 by facade.
The following user(s) said Thank You: GuardianAngel
- VAXXi
15 Apr 2013 06:53 #68723
by VAXXi
Replied by VAXXi on topic Transfer box oil seal leak?
I just changed my 2nd oil seal in the exact same place. Not bothered yet to replace the shaft, although I'm beginning to wonder if there's a reason Suzuki sells them together (seal + shaft) as some other members mentioned.
- renard38
15 Apr 2013 11:13 - 15 Apr 2013 11:14 #68731
by renard38
Replied by renard38 on topic Transfer box oil seal leak?
Last edit: 15 Apr 2013 11:14 by renard38.
- GuardianAngel
15 Apr 2013 12:09 #68733
by GuardianAngel
Replied by GuardianAngel on topic Transfer box oil seal leak?
Thanks all for the responses.
Renard cheers for the photos, I get the idea of how to do it now. What size is the locking nut? I have a limited set of tools so will probably have to go and buy a socket :pinch:
- Johnniehec
- Thank you received: 56
15 Apr 2013 20:59 #68769
by Johnniehec
Replied by Johnniehec on topic Transfer box oil seal leak?
Great pictures Renard!
Time to create page: 0.581 seconds
