Tick tick noise when driving along... From drivers side
13 Mar 2013 20:18 #65575
by minibbb
Tick tick noise when driving along... From drivers side was created by minibbb
I've noticed when driving at low speeds both under power and coasting a tick tick noise coming from the wheel area on the drivers side. It almost sounds like a stone in the tyre when I've checked and they're fine. Any ideas what it could be?
13 Mar 2013 21:17 #65587
by facade
Replied by facade on topic Tick tick noise when driving along... From drivers side
A nail in the tread most likely.
Check all the tyres. I spent ages looking for one in the rear tyre as that was where the ticking sound was definitely coming from, and I eventually found it in the front.
Could be a damaged bearing or disc, or something inside the brake drum, but I'd inspect all the tyres very carefully first.
13 Mar 2013 21:42 #65590
by minibbb
Replied by minibbb on topic Tick tick noise when driving along... From drivers side
Thanks for the reply mate. I had the noise with my old set of wheels and I'm 99% sure its not a screw/stone in the tread but ill double check to be sure, be a cheaper solution mind you!
- Mr. F
04 May 2013 09:02 #69964
by Mr. F
Replied by Mr. F on topic Tick tick noise when driving along... From drivers side
Don't know if you're still experiencing this but I thought I'd answer anyway...
I had exactly the same problem when I bought a new Honda CRV a few years ago (don't have it now) and it took 3 visits to the dealer to find out what it was.
Basically, the little weights that they put on for balancing the wheels were loose and as you drove along they started to make a ticking noise!
04 May 2013 13:17 #69982
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Tick tick noise when driving along... From drivers side
I had it in my first jimny, the pads had been changed but the shims weren't replaced so the pads were rattling. Disappeared when I put my foot on the brakes as the pressure held them in place.
Grey pick up Jimny
- Sprocket
04 May 2013 16:48 #69988
by Sprocket
Replied by Sprocket on topic Tick tick noise when driving along... From drivers side
Hi
My wife had a similar noise on her Octavia. I eventually found a small stone trapped in the front brake caliper. Polished to a mirror finish on side against the disk.
Time to create page: 2.183 seconds
