Removing the mirror glass from the mirror? (1998)
  • Gerula
20 Nov 2012 16:44 #53760 by Gerula
Some idiot cracked my left mirror's glass so now I have to replace it. Was looking to remove the plastic mounting plate but apparently it cannot be removed just by pulling it carefully. The car is a 1998 model (with the bigger mirrors).
Cannot find anything about it on the service manual. Any help will be greatly apreciated :)
  • MWells
20 Nov 2012 17:00 - 20 Nov 2012 17:02 #53762 by MWells
When the glass went on my 1999 jimny i stuck one of these over the cracked glass, it came with a couple of strips of double sided foam tape and is as good as new. Turned up in a couple of days aswell. B)
Mark
Last edit: 20 Nov 2012 17:02 by MWells.
20 Nov 2012 17:07 #53763 by j999pre
I have removed the plastic mounting plate before using a flat bladed screw driver and working round very carefully. Then you can remove the old glass and put in a replacement. Best to warm out all up in the house for a bit first and them use a hair dryer to help fit the replacement glass.
Grey pick up Jimny
  • Gerula
20 Nov 2012 17:37 #53766 by Gerula
Thank you guys, but how did you removed the plastic mounting plate?
  • MWells
20 Nov 2012 20:05 - 20 Nov 2012 20:07 #53781 by MWells
I didn't remove it, just put the stick-on glass on top of the old cracked stuff. The wing mirror is supposedly a sealed unit, according to suzuki who wanted £168 for the near side.
Last edit: 20 Nov 2012 20:07 by MWells.
  • Gerula
21 Nov 2012 00:57 - 21 Nov 2012 00:58 #53806 by Gerula
Damn, that's bad news.
Then I guess the best approach would be to remove the entire mirror, remove the cracked glass, then take the mirror in the house and somehow heat a bit the mounting plate, then install the new glass.
Is the part about tthe sealed unit 100% sure? Maybe they just tried to get your money :)
Last edit: 21 Nov 2012 00:58 by Gerula.
Time to create page: 2.142 seconds
