M16A Engine Swap
  • RichiesJimny
07 Feb 2015 09:57 - 07 Feb 2015 22:23 #137133 by RichiesJimny
Replied by RichiesJimny on topic M16A Engine Swap
Don't even think about fitting a vvt engine in a none vvt car it doesn't work.
Follow this thread and you'll have all the info you need
www.bigjimny.com/index.php/forum?view=topic&catid=6&id=56712
When I swapped my engine I removed both manifolds and tied them back out of the way rather than remove all the pipe work and electrical connectors.
Last edit: 07 Feb 2015 22:23 by RichiesJimny.
07 Feb 2015 14:53 #137151 by Rhinoman
Replied by Rhinoman on topic M16A Engine Swap
VVT and non-VVT ECUs are different.
  • saboor73
12 Feb 2015 13:53 #137686 by saboor73
Replied by saboor73 on topic M16A Engine Swap
a guy swapped a m13a in his car which is for sure a non vvt and he is using this ecu
12 Feb 2015 20:29 - 12 Feb 2015 20:33 #137750 by Rhinoman
The mapping will be wrong and it should throw a check engine light for a faulty VVT system, unless the Indian/Pakistan market has a very different ECU.
Last edit: 12 Feb 2015 20:33 by Rhinoman.
  • saboor73
14 Feb 2015 13:18 #137906 by saboor73
the owner say is not having any sort of problem
  • saboor73
15 Feb 2015 07:11 #137980 by saboor73
plz share the picture of the connection that trigger vvt
Time to create page: 0.195 seconds
