Prop shaft spacer
  • chimpbikes
13 Sep 2012 14:10 #48047 by chimpbikes
Prop shaft spacer was created by chimpbikes
Sorry if this is a silly question but if you fit corrected radius arms for a 3" lift , how do you know if you need prop spacers, do you have to unbolt the prop flanges and see if a gap appears?
Thanks in advance
El Chimpo
  • markyp2000
13 Sep 2012 17:05 #48073 by markyp2000
Replied by markyp2000 on topic Prop shaft spacer
i think its a 1" spacer on a 3" lift and a 2" on a 4 and above if corrected arms are fitted
  • Goat
15 Sep 2012 09:34 #48135 by Goat
Replied by Goat on topic Prop shaft spacer
Think i went with the 12.5 mm spacer with my 3" lift
  • jimnydms
15 Sep 2012 18:55 #48158 by jimnydms
Replied by jimnydms on topic Prop shaft spacer
Hi martin I'm pretty sure what your looking for is whether the front prop shaft has clearance on the mid chassis support bar in front of the transfer box. When I lifted mine my last week the front prop was touching the chassis bar you ll see what I mean when you do it, any probs drop me an email as it's all still fresh in my head :-)
I'm running no front prop at the moment until my crawler box is built and I have had nothing I can't do just in rear wheel drive with new tyres and ora lift
  • markyp2000
15 Sep 2012 19:26 #48163 by markyp2000
what are you on about he didnt say any thing about it and the crossmember it think he would of said if it was you do need a spacer with corrected arms as it move the axle ferther forward talk to rod at offroad armoury or speek to martin on here or find some one with a 3" lift with corrected arms i have a 4.5" lift and befor i put my spacer in it never touched any thing
  • supergaz
15 Sep 2012 21:57 - 15 Sep 2012 22:02 #48171 by supergaz
Replied by supergaz on topic Prop shaft spacer
With a 3" lift and corrected arms the front prop will require a spacer on the transferbox end with a standard jimny transferbox. I have not needed it with my SJ transferbox.
Last edit: 15 Sep 2012 22:02 by supergaz.
Time to create page: 0.719 seconds
