Which way should a snorkel intake face?
  • ne-crock
18 Aug 2012 14:55 #46363 by ne-crock
Which way should a snorkel intake face? was created by ne-crock
Preety much as the title says
Pros and cons of it facing either way?
Cheers
Crock!
  • reaper
18 Aug 2012 15:32 #46366 by reaper
Replied by reaper on topic Re: Which way should a snorkel intake face?
Most of the time front facing but if its raining or dusty just spin it round ,
I dont see any ram air advantage that some may claim with it facing forwards though
  • Paul4x4
18 Aug 2012 17:00 #46369 by Paul4x4
Replied by Paul4x4 on topic Re: Which way should a snorkel intake face?
Just point it forward like it's meant to be, because there's absolutely no reason to face it backwards. If there's dust, it will find it's way into air filter no matter what. And if it's raining the water won't go all the way down into the engine, and even if it somehow manages to get up there the amount would be so little that it wouldn't do any harm. They actually use water to clean carbon build up in engines by pouring it slowly into the intake while the engine runs.
  • ne-crock
18 Aug 2012 19:33 #46374 by ne-crock
Replied by ne-crock on topic Re: Which way should a snorkel intake face?
ah i'll run it front then, got told that running backwards stops bugs etc,
is the snorkel sealed or should i seal it up with silocen if so where?
cheers crock
  • Paul4x4
18 Aug 2012 20:12 - 18 Aug 2012 20:16 #46376 by Paul4x4
ne-crock wrote: ah i'll run it front then, got told that running backwards stops bugs etc,
cheers crock
LOL, the bug issue hasn't even crossed my mind ever! :laugh:
But if anything(dust, bugs, pine cones, squirrels etc) gets sucked into the snorkel, it will be stopped by the filter, so who cares what goes in! :)
EDIT: I haven't fitted a snorkel on my Jimny yet, but as far as I know there's only a little drain hole in the air filter box that needs to be sealed up somehow.
Last edit: 18 Aug 2012 20:16 by Paul4x4.
  • mark1971
19 Aug 2012 13:13 #46394 by mark1971
Replied by mark1971 on topic Re: Which way should a snorkel intake face?
Yeah, seal up the little drain hole in the bottom of the airbox. I also put silicone around the seal where the snorkle enters the airbox through the inner wing.
Time to create page: 1.240 seconds
