knocking/stalling at motorway speed
- JimnyX19
13 Jul 2012 17:45 #44105
by JimnyX19
Replied by JimnyX19 on topic Re: knocking/stalling at motorway speed
my jimny was cutting out on me and dyeing out soon as i was going over 50mph it was the crank sensors that i had change didnt have a problem after it
13 Jul 2012 19:05 #44109
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Re: knocking/stalling at motorway speed
M13a trends to be crank sensor. Its behind the alternator on the engine block. Take a bottle of water and take it for a run. When it cuts out squirt some water on the sensor. if it then starts straight away then that's your problem. About 70 quid from suzuki. Not bad to fit.
Grey pick up Jimny
- ejimny
13 Jul 2012 19:40 #44111
by ejimny
Replied by ejimny on topic Re: knocking/stalling at motorway speed
Thanks again for all your comments,much appreciated
Dean
Dean
- Joakae
14 Jul 2012 07:48 #44131
by Joakae
Replied by Joakae on topic Re: knocking/stalling at motorway speed
This happened to me when I was crusing around Europe. I took it to a zuk garage and they thought it was something to do with the exhaust, so they tried to make me drive back to the UK with it un-attached!
I called a friend in the UK with the problem and he said get them to check the cambelt sensor, they did and were like "Oh yeah..."
Not an expencive fix, but annoying!
- 247sniper
14 Jul 2012 09:56 #44139
by 247sniper
Replied by 247sniper on topic Re: knocking/stalling at motorway speed
Sounds like if could be the crank/cam sensor, these quite often do not leave a DTC in the ECU as the fault symptom only accurs for a split second and the ECU does not have time to store the fault.
Steve.
Steve.
Time to create page: 0.214 seconds
