Unleaded 95 E10
- Northern-Wanderer
10 Jul 2012 23:15 #43928
by Northern-Wanderer
Replied by Northern-Wanderer on topic Re: Unleaded 95 E10
Suzuki say not to use fuel with more than 5%methanol under any circumstances or fuel system damage will occur, and this fuel must contain corrosion inhibitors and cosolvents(whatever they are), but Ethanol upto 10% is ok.Is this the 95 e 10 thats available in France
11 Jul 2012 07:09 #43933
by Obarno
Replied by Obarno on topic Re: Unleaded 95 E10
I think I meant ethanol and not methanol hence the E part of the E10, however there seem very conflicting views as to whether it's damaging to the engine or not. It's the E10 - ethanol additive that is available in France. There is however still ordinary 98 octane available. Good to hear that Suzuki say the 10% ethanol mix won't harm the engines. Also good to hear that Renard uses it without problem.
- bunji81
11 Jul 2012 07:37 - 11 Jul 2012 07:38 #43935
by bunji81
Replied by bunji81 on topic Re: Unleaded 95 E10
Prevention is better than cure IMO. Id use the 98 good stuff, fair enough its a little more expensive, but ultimately it'd work out a lot cheaper than having to eventually replace fuel lines, fuel rails, injectors etc..
Last edit: 11 Jul 2012 07:38 by bunji81.
- Laminak
11 Jul 2012 08:32 #43941
by Laminak
Replied by Laminak on topic Re: Unleaded 95 E10
I use too the SP95 E10 and I have no problem
And my consumption is the same as SP95
- Jenny
28 Aug 2018 09:36 #195484
by Jenny
Replied by Jenny on topic Unleaded 95 E10
I just searched this forum to try to get a clarification of the E10 question after seeing an item on this mornings BBC news about it,
I am conflicted myself. I searched the net for E10 compatibility and found an Australian web site that had a spreadsheet showing compatibility of various makes and models. Here is a link: www.fcai.com.au/environment/can-my-vehic...ethanol-blend-petrol
Basically ALL pre 2008 Jimnys with a SOHC engine are not compatible with either 5% or 10% ethanol fuels. Post 2008 they are as long as the RON (octane) requirement for the vehicle is met.
I own a 2008 model myself.
Personally I will stick to the premium grades of pure petrol because of the additives, higher octane rating and for the sake of fuel economy.
E10 economy is roughly 8 -12% less than straight petrol. In a car that already gets rather poor mileage it means more trips to the pump.
Time to create page: 1.349 seconds
