jimny rear lights
- rjd1
19 May 2012 22:21 #40745
by rjd1
Replied by rjd1 on topic Re: jimny rear lights
sure i read somewhare it was to do with height from road to pass manufacturin laws or something like that
- supergaz
19 May 2012 22:34 #40746
by supergaz
Replied by supergaz on topic Re: jimny rear lights
Grey imports don't have fog lights and require one to be fitted to pass an SVA, If you look at American spec Grand Vitaras ect you will notice the rear light clusters differ from the European spec. Also I use the Grand Vitara as an example as the European spec model uses the same lower light cluster as the Jimny.
- kevinbarry18
30 Sep 2016 18:42 #173040
by kevinbarry18
Replied by kevinbarry18 on topic Re: jimny rear lights
Here is quick solution for you.i did it and it works.
fibre optic cables.
run a thick fibre optic cable from light cluster in rear bumpers to cluster in rear wing.
the light passing tbrough fibre optic cable uses reflector in light cluster....
fibre optic cables.
Time to create page: 1.257 seconds
