stiff clutch pedal
  • myers647
16 May 2012 21:35 #40476 by myers647
stiff clutch pedal was created by myers647
Hi been to look another jimny tonight. Only fault I could find was the clutch pedal when I de-press it it was quite stiff. The biting point was normal but just very stiff what could cause this?????
Thanks
James
  • zuki andy
17 May 2012 12:20 #40514 by zuki andy
Replied by zuki andy on topic Re: stiff clutch pedal
Hi James, if its had a uprated/heavy duty clutch fitted it would make the pedal stiffer to depress. If the cable was seizing up it would be stiff to depress and would be slow to come up.
  • myers647
17 May 2012 13:02 #40517 by myers647
Replied by myers647 on topic Re: stiff clutch pedal
Nice one Andy. Fancy another day out in the Peaks in the near future. If so I will round the lads up from Wakefield there is four of us know all up for it.
James
17 May 2012 14:44 #40520 by mlines
Replied by mlines on topic Re: stiff clutch pedal
Common fault the cable wears through on the inside nylon liner in the cable plus dirt gets in the end. New cable transforms it
Sent from my GT-I9100 using Tapatalk 2
  • myers647
17 May 2012 18:20 #40539 by myers647
cheers martin. Have you got any suggestions as where to get one from. Is this an easy job to do.?
Thanks
James
17 May 2012 18:49 #40545 by facade
Replied by facade on topic Re: stiff clutch pedal
Seen new ones on eBay for £50. Hate to think how much Suzuki want for one.
Easy job to change.
Time to create page: 1.535 seconds
