broken rear shock bolt - done
- Thank you received: 77
01 May 2012 19:39 #39098
by robs5230
standard jimny - for now
Replied by robs5230 on topic Re: broken rear shock bolt - help please
cheers reaper , may be the way to go .
01 May 2012 19:41 #39099
by robs5230
aint even got it home yet an its bust
- dirtydogz
01 May 2012 19:55 - 01 May 2012 19:56 #39100
by dirtydogz
Replied by dirtydogz on topic Re: broken rear shock bolt - help please
The rear shock brackets are only needed if you have got a 2" lift fitted or spring spacers.
Last edit: 01 May 2012 19:56 by dirtydogz.
01 May 2012 20:02 #39102
by robs5230
how dumb do i look ? bought this unseen but its had lots done just not sure what exactly. all will be revealed tomorrow night
- mcjimny
03 May 2012 18:38 #39233
by mcjimny
Replied by mcjimny on topic Re: broken rear shock bolt - help please
The drill bit you need is a HSS bit, not sure on size though. Take it steady though don't have the drill too fast.
- reaper
03 May 2012 18:44 #39235
by reaper
Replied by reaper on topic Re: broken rear shock bolt - help please
If you want to use the bolt through method its a 12mm drill bit , take it nice and slow with plenty of cutting oil or it will just burn up or chip the cutting face
Time to create page: 0.170 seconds
