Airbag light
- goatboy
25 Apr 2012 13:38 #38574
by goatboy
Replied by goatboy on topic Re: Airbag light
Thanks Martin,
So just connect the right hand pin to earth then?
- Johnniehec
- Thank you received: 56
17 Feb 2016 14:16 #162554
by Johnniehec
Replied by Johnniehec on topic Re: Airbag light
Just to resurrect an old old thread can anyone point me in the direction of the "airbag warning lamp Can Not indicate flashing" section please?
My airbag lamp flashes a couple of times on startup then comes on steady but OBDII reader shows no codes.
Happened after I let both batteries go flat then put the battery charger on the starter battery until it had enough charge to start.
Cheers,
John.
Cheers,
John.
18 Feb 2016 19:50 #162654
by Rhinoman
Replied by Rhinoman on topic Airbag light
An OBD2 reader can't read the airbag ECU, you need a Suzuki tool or you need to pull the codes using the monitor coupler.
Time to create page: 2.510 seconds
