Slight Wobble and fast Vibration
  • Dutchjimny
04 Mar 2012 14:27 #34807 by Dutchjimny
Replied by Dutchjimny on topic Re: Slight Wobble and fast Vibration
ive got the ora 3'' castor corrected radius arms too.. But i guess that just wasnt enough..
04 Mar 2012 17:03 #34821 by dirtydogz
This is a track rod end.
Attachment tierod1.jpg not found
2002 JLX Soft Top B)
Jimnybits 2" lift +Pro Comp ES1000 shocks.:) Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
  • darthloachie
04 Mar 2012 22:15 #34861 by darthloachie
Replied by darthloachie on topic Re: Slight Wobble and fast Vibration
dirtydogz wrote: This is a track rod end.
there's 4 of them on the Jimny and are part of the steering setup and are what connects the hub to the steering rack to allow the the wheels to turn
  • blakey2000
05 Mar 2012 08:27 #34888 by blakey2000
Replied by blakey2000 on topic Re: Slight Wobble and fast Vibration
@ dutchjimny, oh really wow, how do i know if my kingpins are aligned incorrectly. is it a visual thing that i can just look to see.
@dirtydogs and darthloachie,
thoes ends on my jimny, the bushing is pretty rooted does that affect them much
and i have come across something that give a decent list of what causes the wobble on a jimny i can copy the thread over if others would like to see it or at least give a link
  • darthloachie
05 Mar 2012 12:24 #34913 by darthloachie
give them a good shake
mine had worn enough to rattle when you shook them - cured one of the wobbles we had
  • Jimbo in the Jungle
05 Mar 2012 18:27 #34955 by Jimbo in the Jungle
Replied by Jimbo in the Jungle on topic Re: Slight Wobble and fast Vibration
I have also installed a 3" lift. I am not having any wobble issues but my rear driveshaft CV was already a bit tired and I think with the increase in angle it is on its way out.
I would be interested to know whether you installed any prop shaft spacer on the rear driveshaft - I have not yet installed any as the 1" spacer was too tight a fit but I have turned it down to 1/2" and will probably see if it improves matters.
Good luck with it.
Jim.
Time to create page: 0.364 seconds
