Dash showing engine temp is realy hot! NOW SOLVED!
29 Nov 2011 16:44 #26891
by kirkynut
Replied by kirkynut on topic Re: Dash showing engine temp is realy hot!
I think I would still lock the fan up and try it before spending money at a garage.
- jo king
29 Nov 2011 17:00 #26893
by jo king
Replied by jo king on topic Re: Dash showing engine temp is realy hot!
Yeah I would tie up the fan just incase it is faulty at higher revs.
But I have no clues of how this is acheived :huh:
Picture would be good
- Nobby22
29 Nov 2011 17:02 #26894
by Nobby22
How do you actualy lock it up with cable ties? Am i locking the metal caseing to the fan? I carnt work how to do it :blush: A "how to" would be most useful
Nobby
Replied by Nobby22 on topic Re: Dash showing engine temp is realy hot!
kirkynut wrote: I think I would still lock the fan up and try it before spending money at a garage.
Nobby
- teafortwo0789
29 Nov 2011 18:51 #26896
by teafortwo0789
Replied by teafortwo0789 on topic Re: Dash showing engine temp is realy hot!
I like the idea of being able to do a temporary 'tie up' with cable ties for when I know I'm going to do a heavy duty cycle and then remove when light going. just don't know how its done.
- Nobby22
30 Nov 2011 18:34 #26952
by Nobby22
After a bit of research on google i think i sort of know how to do this. Or at least the theory. Somehow i need to cable tie the fan to the shaft it spins on. Is this right? This will cause the fan to spin fully all the time and so replicateting when the viscous fan clutch is engaged.
I think i will give this a go. I surpose i will be able to hear the difference when the viscous clutch engages?
Nobby
Nobby
- Nobby22
01 Dec 2011 19:33 #27028
by Nobby22
I just did a small test that is recomended to help determine if the viscous fan has failed or not. Basically you get the engine up to temperature, a temperature when the fan clutch should kick in. Then turn off the engine and check the fan to see if you can move it. In theory you shouldnt be able to move it as the clutch should be engaged, thus locking it to the shaft. Well on mine the fan can easily be turned and if anything moves easier than when the engine is cold :ohmy: . Tommorow i will have a go at locking it up and hopefully prove its the fan at fault. Stayed tunned
Nobby
Nobby
Time to create page: 0.310 seconds
