Kingpin Bearing Grease?
  • Jimaroid
16 Feb 2011 17:43 #11628 by Jimaroid
Replied by Jimaroid on topic Re: Kingpin Bearing Grease?
Related to this, what type of sealant do people use on the kingpins?
  • bryandenham
16 Feb 2011 20:49 #11647 by bryandenham
Replied by bryandenham on topic Re: Kingpin Bearing Grease?
none!!
  • George 147
16 Feb 2011 21:07 #11649 by George 147
Replied by George 147 on topic Re: Kingpin Bearing Grease?
I've just done one side on mine found the bolt heads had become quite badly corroded on the king pins swivel seal and half shaft retaining bolts probably due to brake dust /mud etc. Managed to get everything undone but several bolts got destroyed on the way splashed out and replaced all with stainless ! Just be warned. on the subject of sealant I used a smear of instant gasget any type will do. Good Luck
16 Feb 2011 22:00 #11651 by JonathonMarshall
what size/type of bolts just in case?
  • George 147
17 Feb 2011 20:22 #11679 by George 147
Swivel seal bolts M6 x 1 x 10mm 16 in number
King Pin Bolts M8 x 1 x 20mm 16 in number
Drive Shaft bolts M10 x 1.25 x 25mm 8 in number
Thats the quantity to do both sides
  • biggaz
17 Feb 2011 20:43 #11685 by biggaz
Replied by biggaz on topic Re: Kingpin Bearing Grease?
bryandenham wrote: hiya,
if you are only changing the kingpin bearings you DON'T need to dismantle the hub.
Remove vacuum pipes, remove caliper and hang out of way, no need to disconnect brake pipe.
Remove large seal, (ring of bolts).
Remove kingpins, eight bolts, four top, four bottom.
Draw off complete hub and half shaft assembly.
ALWAYS replace small internal oil seal.
Knock out bearing tracks, gently with a small cold chisel, easy but fiddly.
Clean carefully.
knock in new tracks, (the right way round !), careful.
fit bearings, LOTS of grease.
replace small seal.
put everything back together.
Job done, half an hour each side !!!!!!
I ALWAYS use waterproof grease on the king pin bearings and before any clever dick says all grease is waterproof, its not it can emulsify with water. Water pump or underwater grease is easily obtainable and completely solves the problem of water causing the kingpin bearings to rust.
Only use the correct driveshaft coupling grease on the couplings though because it is high pressure grease and is also anti fling.
If you are an engineer then a grease nipple can just be squeezed in but you do need to know what you are doing.
Hope thats a bit clearer than mud
all the best Bryan D
very helpfull, when are you coming to do mine! :lol: :lol:
