what do you think about this clutch kit ?
  • jimnyjim
26 Jan 2011 19:26 #10395 by jimnyjim
hi my clutch has started to slip and bite is high :( so been looking at new kits and have found this one can you help and tell me what you think and if it will make a difference being an organic clutch kit cheers :) heres the link
cgi.ebay.co.uk/SUZUKI-JIMNY-1-3-16V-HEAV...&hash=item41561628b4
26 Jan 2011 19:41 #10398 by facade
Before doing anything else, is the cable adjusted so there is a little free play?
As the plate wears, the biting point moves up the pedal.
The adjuster is at the lower end of the cable where it can corrode and seize up :dry:
Don't know about the eBay kits, sorry.
  • jimnyjim
26 Jan 2011 19:48 #10400 by jimnyjim
Replied by jimnyjim on topic Re: what do you think about this clutch kit ?
thanks for the reply :) is the adjuster on the cable where it goes into the gearbox ? if so how do you adjust plus the clutch is slipping abit at the moment so if i adjust it wont that make it slip worse ?
  • vitara_mad
26 Jan 2011 20:38 #10414 by vitara_mad
Replied by vitara_mad on topic Re: what do you think about this clutch kit ?
don't waste your money on that ebay clutch that says its heavy duty they are a recon clutch with the pessure plate painted red & you can buy a recon for £50 or brand new for £95
26 Jan 2011 21:14 #10418 by facade
To adjust,
simply (hah :silly:) rotate the plastic adjuster wheel so as to reduce the amount of thread on the side going towards the clutch pedal until there is a little free play at the pedal end. IIRR there is a rubber thingie that stops it rotating by itself that you have to deal with., must be obvious as I managed to adjust mine ;)
You will likely find that the adjuster is seized solid though, remove the plastic box on the gearbox and unhook the cable, then it pulls out to clean up the thread with a wire brush and penetrating oil.
You will need to adjust the cable when you fit a new clutch anyway so it won't hurt to free it up and adjust it.
This hopefully will move the biting point nearer to the floor and make the clutch lock up.
Time to create page: 0.278 seconds
