Passenger window switch broken
- Zen76
01 Sep 2023 00:03 #250609
by Zen76
Passenger window switch broken was created by Zen76
How do I manually close my power window when the switch is broken??
01 Sep 2023 00:48 #250610
by fordem
Replied by fordem on topic Passenger window switch broken
Remove the door card, unplug the motor and connect it directly to a 12V DC source, if it moves down instead of up, reverse the polarity.
01 Sep 2023 09:53 - 01 Sep 2023 09:59 #250615
Replied by yakuza on topic Passenger window switch broken
not sure if possible but not so difficult to flip the switch panel out, and see if it is possible to pull the plug from driver side switch to passenger side switch to get the window up.
edit: Checked images, not so easy as i hoped. If you find a wiring diagram you could just short the correct wires there without removing door card.
Last edit: 01 Sep 2023 09:59 by yakuza.
- Thank you received: 1876
01 Sep 2023 10:10 #250617
Replied by Lambert on topic Passenger window switch broken
Just before you take it apart you have checked the window lock button at the front of the driver side switch panel.
01 Sep 2023 13:12 - 01 Sep 2023 13:13 #250623
I have no idea what that button actually is good for, other than confuse the owner.
Come to think of it, it can better be reused for something useful, I'll think of something some day..
haha this one should be on auto when this comes upJust before you take it apart you have checked the window lock button at the front of the driver side switch panel.
Last edit: 01 Sep 2023 13:13 by yakuza.
- Zen76
02 Sep 2023 23:19 #250643
by Zen76
Replied by Zen76 on topic Passenger window switch broken on my Jimny 2002 (M13A)
Thank u for your reply what has happened is the switch toggle is broken on passenger and driver side looks like non genuine parts used being that it is simply the switches that are broken should I still try running wire from motor to 12V/DC power source??
Time to create page: 2.039 seconds
