Anyone know how to remove/lift up the rear seat base? (Gen 4)
- Thank you received: 208
08 Nov 2022 11:05 #245801
by 300bhpton
It feels like it is clipped in place on either side if I try and lift from the front, but I don't want to force it. Or does it lift up from the back of the seat base? Not sure if there are any release clips, I couldn't see anything, but also couldn't get the seat base to lift up either.
I've had a flick through the manual, but couldn't see anything obvious.
Thanks.
Thanks.
08 Nov 2022 12:40 #245803
by fordem
Replied by fordem on topic Anyone know how to remove/lift up the rear seat base? (Gen 4)
If I recall correctly, just grab it and yank - I know I've had mine out to get behind the side panels to the speaker wiring.
The following user(s) said Thank You: Gadget
08 Nov 2022 12:42 - 08 Nov 2022 12:51 #245804
by fordem
Confirmed - hold near the front outer edges and yank upwards.
Last edit: 08 Nov 2022 12:51 by fordem. Reason: add info
- Thank you received: 560
08 Nov 2022 14:08 #245805
Replied by DrRobin on topic Anyone know how to remove/lift up the rear seat base? (Gen 4)
If it is the same as a Gen 3, they have a couple of spring clips at the front and a couple of wire loops at the rear that fit under brackets. My Gen3 is very tight, it takes a good sharp pull to free the clip off.
As you say, just pull it up from the front, near to the sides.
09 Nov 2022 10:38 #245839
by 300bhpton
Replied by 300bhpton on topic Anyone know how to remove/lift up the rear seat base? (Gen 4)
Many thanks. Got it out, it did need quite a bit of force.
Time to create page: 1.746 seconds
