gen4 cruise control minimum change
09 Oct 2022 18:30 #245349 by lookonimages
Martin & co
I would like to know if someone has been able to change minimum value via a car reader/program device to allow cruise control to operate below factory settings.
The version selling in South Africa currently only work if you go 40km/h or faster.
the reason I ask is that here we have vast routes and nature reserves where you really could be idling along all day at 20km/h in 2nd/3rd gear.
I have had serious car accident and my "accelerator" foot has been "fused" with limited function and having to use accelerator pedal all the time below 40km/h when you on 4-5 hour trip, then it becomes a nightmare.
much appreciated your feedback.
10 Oct 2022 04:40 #245356 by Lambert
Have you considered a hand throttle modification, there's bound to be a local specialist at converting cars for amputee use that could have an off the peg solution?
10 Oct 2022 13:04 #245366 by lookonimages
Lambert wrote: Have you considered a hand throttle modification, there's bound to be a local specialist at converting cars for amputee use that could have an off the peg solution?
yes I am definately considering this but
thought maybe change parameter in ecu would be "cleaner" installation :)
11 Oct 2022 07:18 #245383 by lightning
Most cruise controls won't work below around 40km/h
You could as suggested make a device that increased the engine idle speed, then you could use (say) third gear to sit at 20-30km/h
The following user(s) said Thank You: lookonimages
Time to create page: 0.176 seconds
