Roof box position
26 Sep 2022 13:59 #245132 by Lambert
Roof box position was created by Lambert
I'm just about to inherit a smaller roof box which is too short to fit between the fixed cross bars I have. Not a problem as I can get some aluminium box section to interface between the two. Question is which is the better end of the roof to mount it? Forward to better use the windshield as a deflector or rearward to better position the load onto the back axle? Yes I know it's all marginal on any benefit either way but I like to do the best I can for my OCD. I also appreciate the massive improvement in mpg I am going to have with a roof box and all terrain tyres but it is for the benefit of the dogo having more comfortable traveling arrangements for the trip to Wooler.
26 Sep 2022 15:11 #245134 by fordem
Replied by fordem on topic Roof box position
I feel the further back the better - my experience has been that anything close to the front edge of the roof creates quite a bit of wind noise.
26 Sep 2022 17:39 #245136 by Lambert
Replied by Lambert on topic Roof box position
Thanks that's what I was thinking, but it's my first roof box so I have no point of reference.
27 Sep 2022 05:37 #245143 by Lambert
Something else has just occurred to me. Is there any reason why I couldn't fit the support aluminium bars under the fixed cross bars to keep the profile lower? I might use m 8 hardware instead of M6 just for peace of mind. Is it going to create more wind noise if the gap to the roof is quite narrow or will the reduction in frontal area help reduce that?
29 Sep 2022 17:12 #245206 by Busta
Replied by Busta on topic Roof box position
Put the centre of drag behind the centre of mass for maximum straight line stability.
But mostly just put it wherever it looks right. Must be quite a short one to not cover the entire roof!
29 Sep 2022 18:36 #245211 by Lambert
So my intuition has some science in it, good to know. Yes it's quite short and does look better further back. It's also better under slung as it were relative to the cross bars. I just received the u bolts so I can finish fitting it on Saturday. Pictures will follow.
