Re:G'day from Oz
30 Mar 2022 13:44 #242585
Replied by Soeley on topic G'day from Oz
- stimpy
30 Mar 2022 22:24 #242604
by stimpy
Replied by stimpy on topic G'day from Oz
Thanks Lambert. Here are a couple of photos. Not sure if you'll see anything in particular but it has been raised 50mm (body lift and larger tyre profile). I'm not used to too many 4WD experiences. This is my first. Still getting used to it. I have to smile to myself every time I get in and out of the thing. Getting in takes an extra-large step, and exiting is more of a turn-and-slide to the ground effort. Not particularly elegant. I don't know how Landcruiser folks manage that have been raised a huge distance off the ground.
I had to double take at the pictures.... Wondered what that blue was in the back ground..... I remember now .... From a visit to Spain where I basked in the glory of warm sunshine
Jimny looks good.
- Ron0z
31 Mar 2022 04:16 #242607
by Ron0z
Replied by Ron0z on topic G'day from Oz
Now that's weird. It being referred to as a money pit. I'm seeing some of it now. And I've only just got it home. And all to do with vehicle registration. That may be what you call MOT fees over there.
When I saw the car it seemed very nice. It had an upgraded radio (with GPS and other stuff, half of which I can't work out), a CB radio, some power outlets, and the two back seats had been removed and storage shelves with a drawer had been fitted in their place. On the outside, it has a winch, some spotlights, larger profile tyres, and has been lifted 50mm. It also had a bull bar and a front and rear tow bar. It came with the roof rack and awning and the seller threw in the rest of the tent that goes with it. In addition, I was provided with the old radio that had been removed, the old coil springs and shock absorbers, the original front bumper bar, and the two rear seats. The car also had a second battery installed with some sort of cut out with it for when the volts start to drop. There were other little bits and pieces that I might never use. Oh, yes. It also has breathers from the diffs and gearbox mounted under the bonnet as well as a snorkel. I also have an anti-sway bar I suppose you'd call it except it swivels rather than resists; he mentioned that with a smile. He said I might want to put it on for fun one day. And I almost forgot. He gave me a recovery kit as well.
The car had one other thing that even the seller didn't know about. Something that I discovered later when I took it for its roadworthy inspection. It has a 1.6 L engine.
So, my sorry state started when I took it to a local garage to have a vehicle roadworthy inspection. All new purchases have to be checked over by an authorized workshop. I got a call from the mechanic quicker than expected. "I can't do this," the guy said. "Why not?" "It's had an engine change. You'll have to take it to the government." At least he didn't charge me. He seemed grumpy. Probably because he didn't get any money out of me. I bought the car thinking it had a 1.3 L engine. This one has a 1.6 L engine. No, not 1.5 at least not according to the engine number.
At the completion of the inspection I was provided with a report that indicated where the car failed, and one of the items was the engine. I needed to take the car to a qualified engineer to have it certified before it could be registered. Not a mechanic. I'm wondering if engineers charge the same price as lawyers.
Happily, the engineer I rang had had a cancellation and I could take the car to him within a few days. He was a very pleasant guy. Well, with people like me giving him $1800 for his work he would have to be. The good news was that the engine was fine. It had been fitted well, had next to nothing on emissions, and got a big green tick. But this guy was thorough. He noticed the leaking diff oil coming out behind one of the rear backing plates. The roadworthy guys missed that. There were lots of little things he picked. Some not so little, but the really big thing was yet to come.
He took the car over a weighbridge and compared what he got against the manufacturer's specs. The difference being the bits and pieces that had been added. The modifications. The bull bar would be heavy. So would the winch, and no one can deny batteries are heavy too, and the two tow bars would have added to it, and no doubt the various undercar protection the seller boasted of all add weight. I'm not so sure about the springs that were changed in lifting the car 50mm but they would add a bit. So, here's the thing. The car has a certain load carrying capacity; like for four people, but that's with no modifications. If you add weight in other ways, as noted above, then there is less carrying capacity for passengers. It seems with all the extra weight that's on my car it would be illegal to drive it with any more than the driver, because it would be overloaded.
The solution to this hit me with another shock. The engineer suspected that since all of the work done had been done well that the car probably would be okay to carry passengers, but it would have to be tested. If the car was certified at a higher Gross Vehicle Mass (GVM) then it could be registered. GVM tests are $2200 to complete. The alternative is to remove the heavy stuff. I want to keep the winch etc so I'm digging deep into my pocket.
Yup. It's a money pit. Oh, yeah. I gather I'm up to $1000 on the oil leak and new rear brakes.
- Thank you received: 1869
31 Mar 2022 04:39 #242609
Replied by Lambert on topic G'day from Oz
Ouch. This is something I keep on about is just how heavy some of these modifications make a jimny. Yes they're useful but if you end up overweight that's not good. Unfortunately over here the testing process doesn't seem to account for weight particularly so people tend to ignore it. It can however bite back if the insurance think it was a contribution to a collision or you are unlucky to get a roadside inspection by a government body. Personally I keep a very close eye on the weight of mine because I do a lot of cargo and towing work on my farm and a Jimny with a trailer is a very appealing target for a roadside inspection.
- lookonimages
- Thank you received: 65
31 Mar 2022 07:57 #242611
by lookonimages
Replied by lookonimages on topic Re:G'day from Oz
welcome.
- Roger Fairclough
- Thank you received: 211
31 Mar 2022 08:25 #242613
by Roger Fairclough
Replied by Roger Fairclough on topic Re:G'day from Oz
I receive Emails from an Aussie 4x4 magazine and the authorities are forever clamping down on overweight combinations of 4x4s and caravans. They set up road side weighing stations and fines are heavy. Over here we wait until someone has an accident, the media have a field day and 24 hours later they are back to reporting on subjects that really matter (to them that is).
I towed the club caravan behind my Gen.2 and nearly lost it going down a steep hill when it started to snake. That was nasty.
Our hearts go out to you (but not our cash) and hope your troubles will soon be a thing of the past.
Roger
Roger
Time to create page: 4.410 seconds
