Gen 3 Tyre Sizes - Sorry In Advance
- louchy
22 Jan 2022 20:49 #241417
by louchy
Gen 3 Tyre Sizes - Sorry In Advance was created by louchy
Good Evening All,
I have been reading through as many of the tyre threads as possible, and I am still a little confused, so would really appreciate the advice of all the experts (really sorry for adding yet another tyre thread )...
First Question
From what I can gather so far the maximum size of tyres on standard Get 3 alloys with a MK1 bumper and no lift, without any rubbing (or mods required) would be:
New Tyres: 215/75/15 - (BFG, General Grabber, Kumho etc.)
Remoulds: 195/80/15 - (Insa Turbo etc.)
Did I get this correct??? If not please advise....
Second Question
Would the same maximum tyre size quoted above, still fit without rubbing on a set of new 0-offset steel wheels from Jimnybits or Raptor4x4? Or would the difference in offset of the steels cause some rubbing or mods needed?
Third Question
What would be generally recommended, a set of new tyres, like the BFG's for example at the larger size, or remoulds? I suspect my driving will be 80% off road and 20% on road. I am edging towards 215/75/15 BFG AT's , but any recommendations for a newbie would be much appreciated.
Final Question
Would all options mentioned above still look ok after a 2" lift? I plan to get the tyres first and do some off roading, then do a spring lift if I feel its required, which I suspect it will be rather quickly. To be honest, I might even just get the lift done at the same time as the tyres as I tend to be quite impulsive
Once again, sorry for all the questions, I hope when I learn some more, I can contribute to help others on here. And as always, all advice is hugely appreciated.
Thanks,
Chris.
First Question
Second Question
Third Question
Final Question
Thanks,
Chris.
- Thank you received: 1983
23 Jan 2022 06:05 #241420
Replied by Lambert on topic Gen 3 Tyre Sizes - Sorry In Advance
You are right about the sizes on standard wheels. The issue with the steel after market wheels is not only the off sets but also the additional width of the wheel causing the tyre to be more stretched at the bead which can also affect body clearance. Its also worth mentioning that the tread pattern will also have a bearing on clearance too as a more aggressive pattern will have more shoulder and side biters which will reduce clearance. Generally speaking though 215s and 195s are usually fairly straightforward to fit.
The following user(s) said Thank You: louchy
23 Jan 2022 07:01 #241421
by me101
2007 Little Jim with cheap mods!
www.youtube.com/channel/UCeBDekO99Qk2aOmBmSmrI9w
Replied by me101 on topic Gen 3 Tyre Sizes - Sorry In Advance
I'd agree with Lambert. Also, if you go for a 2" lift, they will still look fine. I have had both sizes (195/80 Insa Dakar and currently 215/75 Maxxis Wormdrive) on my 2" lift.
- louchy
23 Jan 2022 09:51 #241422
by louchy
I think I will go with some 215/75/15's, and my choices are to either fit to my standard alloys then switch to lift / steels later, or I do it all at once.
Thanks,
Chris.
Replied by louchy on topic Gen 3 Tyre Sizes - Sorry In Advance
Thanks Lambert, that's really helped.You are right about the sizes on standard wheels. The issue with the steel after market wheels is not only the off sets but also the additional width of the wheel causing the tyre to be more stretched at the bead which can also affect body clearance. Its also worth mentioning that the tread pattern will also have a bearing on clearance too as a more aggressive pattern will have more shoulder and side biters which will reduce clearance. Generally speaking though 215s and 195s are usually fairly straightforward to fit.
Thanks,
Chris.
- louchy
23 Jan 2022 09:52 #241423
by louchy
Thanks Me101, good to know that I can do it in stages and the tyres will be ok pre and post liftI'd agree with Lambert. Also, if you go for a 2" lift, they will still look fine. I have had both sizes (195/80 Insa Dakar and currently 215/75 Maxxis Wormdrive) on my 2" lift.
24 Jan 2022 08:19 #241448
Replied by yakuza on topic Gen 3 Tyre Sizes - Sorry In Advance
Also important with larger tire size is the gearing. more than 215 will affect the performance. Next step 235 tires on a 80hp m13a with original gears is very boring, i know, i been there. And your low range is less useful as well so no apperent improvement other than the looks.
Stay with the 215 until you can change the gears.
Time to create page: 1.765 seconds
