Re:Re:Pre runner suspension
17 Oct 2021 18:16 #239483 by Busta
Replied by Busta on topic Re:Re:Pre runner suspension
Cool though it would be, I can't see it working with the Jimny's short wheel base. If you want to make something work with the Jimny's small footprint you'd be better off looking at side by sides and their fully independent suspension to get the unsprung mass as low as possible.
18 Oct 2021 03:26 #239487 by Lambert
Replied by Lambert on topic Re:Re:Pre runner suspension
The other thing is the weight. The body/chassis has to have enough mass relative to the axles to not be unduly distributed by the movement of the axles in order to get the floating effect. Which given the stress on the axles requiring them to be strong and therefore heavy by turns means the chassis will also have to be heavy too. Like I suspected less and less Jimny is going to be left.
18 Oct 2021 09:26 #239491 by Busta
A LWB Vitara would be a better starting point. Longer, stronger rear axle, independent front suspension.
I don't think overall weight is so important. It's more to do with the suspension. Check out the price of that before you get the angle grinder out!
18 Oct 2021 10:08 #239493 by Lambert
5 way bypass King 3.0 dampers yeah I'll have 6 sets as spares! Assuming someone has a mansion I can mortgage against! Anyone?
18 Oct 2021 13:23 #239499 by Scimike
Replied by Scimike on topic Re:Re:Pre runner suspension
Interesting concept and something I have no idea about.
My stupid thinking has the solid axles as problem 1, following by the chassis mods to incorporate the changes required to get rid of this design.
The fact the Jimny body is light is a bonus???
With this in mind why on drop a body on something like this, modified to mate the parts together and with bigger tyres.  Maybe a Hayabusa engine for a bit more speed. (Believe the Jimny 1.3 has some Hayabusa parts!)
Do you need to follow any particular design to qualify as a pre-runner, or can anything go?
18 Oct 2021 14:13 #239500 by Roger Fairclough
Lambert.
You ask for our thoughts on a Jimny derived vehicle able to travel across undulating terrain at high speed and then illustrate the concept with a video showing desert racing motors doing just what you ordered.
Why then label them "this sort of silliness".
Is that label for the cars or the drivers?
Roger
Time to create page: 0.997 seconds
