Jimnybits Front Shock Mount Guards?
15 Oct 2021 19:02 #239435
by LM42
Jimnybits Front Shock Mount Guards? was created by LM42
Any pictures of them installed? Worth it?
Sent from my Redmi Note 8T using Tapatalk
- Thank you received: 1960
16 Oct 2021 04:27 #239444
Replied by Lambert on topic Jimnybits Front Shock Mount Guards?
When I had them on Dreadnaught with the trailmaster dampers I had to countersink the back axle bolts to get clearance. As to being worthwhile I haven't fitted any to Temeraire and I'm unlikely to bother.
16 Oct 2021 04:30 #239445
- Thank you received: 923
24 Oct 2021 10:00 #239589
Replied by X8GGY on topic Jimnybits Front Shock Mount Guards?
I always fit these to my builds... as well as protecting the susceptible flimsy original bracket they also bolt onto it to stop it shearing off
Fitted pic -
See how the longer shock bolt goes through the 5mm steel guard and then through the original bracket and shock, thus also supporting the shock and it's mount....
And they end up at basically the same height as the bottom of the radius arm, so no ground clearance is lost -
[i,g] www.bigjimny.com/media/kunena/attachments/1070/DSCN9449.JPG [/img]
(Photos from Boogie build thread)
Fitted pic -
24 Oct 2021 12:01 #239594
24 Oct 2021 12:03 #239595
by LM42
Replied by LM42 on topic Re:Jimnybits Front Shock Mount Guards?
thank you again! Need 3!
Time to create page: 0.192 seconds
