Freeway RPM Auto vs Manual ?
  • Francis26
28 Jun 2021 06:53 #236194 by Francis26
Freeway RPM Auto vs Manual ? was created by Francis26
Hi.
I’m looking at buying a 2021Jimny, but I’m being really indecisive about what transmission to go with.
I need to drive the freeway to get to my local 4x4 trails. Which transmission sits at the lower RPM’s at 100km/hr? If it was a modern transmission (5 gears +) it was probably be an easier decision.
28 Jun 2021 08:10 #236196 by saxj
Replied by saxj on topic Freeway RPM Auto vs Manual ?
If your primary use is off-road, then go with the auto. If you are more concerned about on-road revs then go with the manual. The auto is only a 4 speed, and when it changes down to 3rd for hills you are at 5500rpm.
28 Jun 2021 08:16 #236197 by Lambert
My new auto gen3 is much calmer on the motorway and is pulling around 3200 to 3800 in normal cruising. My older manual was just under 4000. The newer 4s may be slightly different.
28 Jun 2021 08:28 #236199 by 300bhpton
I guess that is down to personal preference. Personally prefer manuals off road.
28 Jun 2021 08:29 #236200 by 300bhpton
I beleive the manual JB74 is geared for approx 20mph/1000rpm in top. So 60mph (near to 100km/h) is about 3000rpm on the tacho.
28 Jun 2021 08:51 #236201 by saxj
The traction control on the JB74 works very well with the auto. With the manual it's very easy to stall when the traction control kicks in.
Time to create page: 2.073 seconds
