Alternator again!!!?,!
02 Mar 2021 23:46 #233411
by Fossie
Replied by Fossie on topic Alternator again!!!?,!
No I haven't , but then it's been dealt with 3 red party so to speak,.
Stuff me if today the recovery chap arrived to drag the one with stuck brake on .....and if had soddin'freed off......
So I should bringing it back up here soon so will check belts and pulley , so will add dressing spray ....it can't harm can it" cheers .
20 Mar 2021 23:27 #233869
by Fossie
Got a new crank pulley on order, aswell as a dayco belt ..
To night I noticed that when I turned on the headlights there was a ...let's say whistle , kinda electrical type ...when I turned it down to sidelights , t stopped...h/ lights on whistle ..The alternator is just 2 months old
Very odd the radio occasionally looses the station but then finds the one it was on ...
Connected? ( pun intended or not !).
- Thank you received: 1975
21 Mar 2021 06:18 #233872
Replied by Lambert on topic Alternator again!!!?,!
Was the alternator a rebuild or a new one and if so from where?
21 Mar 2021 10:17 #233875
by Fossie
It was a new alternator but as it was my daughters local garage that did the job ...only charged her for the alternator not labour as it was just out of warranty ...so not a case of just making money!
So basically there local parts supplier I guess ...they are in Princes Risbourgh ( near Wycombe) ....so whom ever people use there.
Hoping to get this sorted in next few weeks so she can finally come home to visit her friends up here and go home in hers ....serviced cleaned and a new bill of health.
27 Mar 2021 21:28 - 27 Mar 2021 21:36 #234075
by Fossie
Got the new crank pulley and dayco belt, decided to ask local mechanic to fit it because having perused these pages it seems a pig of a job, Anyway he charged me £60 ...including taking rad off , cleaning the water pump pulley grooves on his bench ....and yep I wouldn't have got the old pulley off without an impact tool!
The old pulley wasn't sepreated or seems damaged ...bugger ......then on a closer inspection their seemed to be a machined notches in the grooves ...very odd....
Then with a screw driver blade I found out it was old bits of rubber and grit basically the grooves were about 1mm full the 'machined' notches the clear bits!..so maybe this could account for slippage .....we will see.
Just the King pins and rear shocks to do while I've got it .....
Last edit: 27 Mar 2021 21:36 by Fossie.
Time to create page: 0.174 seconds
