How to measure my front shocks and what size do I need
- Cutler
16 Dec 2020 20:26 #230936
by Cutler
How to measure my front shocks and what size do I need was created by Cutler
So I’ve got a lift on my jimny bought like this so unsure what size and I’ve ruined a shock I now need to buy a new one and I’m unsure on what size is needed if anyone can help please
16 Dec 2020 21:59 - 16 Dec 2020 22:01 #230942
by Scimike
Replied by Scimike on topic How to measure my front shocks and what size do I need
Hi,
How did you damage the damper, snapped or just leaking?
The simple way is to just measure the current damper length and get a replacement that meets or exceeds these measurements.
This however assumes that you have the correct dampers fitted to suit the vehicle articulation. This is why I asked the first question, trying to gauge if they are correct or stressed.
If you are uncertain the next step is to measure the vehicle articulation to size the damper to your suspension movement.
Here's an article to try and explain it better.
www.superiorengineering.com.au/how-to-measure-a-shock-absorber
Alternatively try and find the make of lift kit you have fitted or any remaining part numbers on the current dampers.
Mike
Mike
Last edit: 16 Dec 2020 22:01 by Scimike.
- Cutler
16 Dec 2020 22:10 #230944
by Cutler
Replied by Cutler on topic How to measure my front shocks and what size do I need
It’s a bit odd it rises and drops with to much ease it bangs over every bump ( I’m assuming this is just a broken shock) which has also lead to it bending as I drove it home like it and I’m confident they’re the correct size as they’ve lasted the whole time I’ve had the vehicle and the guy knew what he was on about theyre black raptor shocks I will have a look at the link try and educate myself a little . Thanks for replying
- Cutler
16 Dec 2020 22:15 #230945
by Cutler
Just read the link this had everything needed thank you
16 Dec 2020 23:42 #230950
Replied by jackonlyjack on topic How to measure my front shocks and what size do I need
The black raptor's are from jimnybits
If you need one they closed from 18/12 opens 4th jan
Time to create page: 0.171 seconds
