Re:Re:Re:Re:Jimny commercial
29 May 2021 16:33 - 29 May 2021 16:34 #235468 by lightning
Replied by lightning on topic Re:Re:Re:Jimny commercial
And hopefully a hybrid power plant. That would make a lot of sense as an LGV.
Last edit: 29 May 2021 16:34 by lightning.
30 May 2021 09:40 #235479 by Foxtrot
Replied by Foxtrot on topic Re:Re:Re:Jimny commercial
There seems to be a lot of speculation with the engine that will be put in the LWB Jimny, one report suggests
"According to rumours the Jimny LWB can be offered with a more powerful 1.4-litre turbocharged petrol engine that is doing duty on the Swift Sport. This will be done because the Jimny LWB is a larger and heavier vehicle. The 1.4-litre turbo petrol produces 127 hp of max power and 235 Nm of peak torque. "
30 May 2021 11:56 #235482 by Roger Fairclough
The battery pack on a Tesla weighs in at 500kg. Obviously a battery pack on a hybrid design for the Jimny would weigh a lot less, but it would still be substantial and would reduce the weight carrying capability of a commercial variant.
Roger
30 May 2021 12:05 #235483 by Lambert
Replied by Lambert on topic Re:Re:Re:Jimny commercial
I'm not convinced that the utility of the extra space in a long wheel base is going to offset the increase in weight and the decrease in maneuverability that go hand in hand with a bigger platform. I have noticed that this last week as I have been using Leviathan as my daily, whilst small and agile for what she is Leviathan struggles with maneuverability that I simply didn't register when doing the same task in Dreadnaught, an extra meter on the turning circle is the difference between being able to reverse a trailer into a gateway and having to uncouple and heave about manually. I would be worried that a long Jimny could be just a little too numb?
30 May 2021 12:36 #235484 by Roger Fairclough
Is there a difference in turning circles as supplied by Suzuki between Dreadnaught and Leviathan or did you modify Dreadnaught to give you a better turning circle?
Roger
30 May 2021 13:47 #235486 by Lambert
Leviathan is a swb 155 cruiser commercial sp about 800mm longer over all and 400mm longer wheel base also wider and heavier but potentially not too dissimilar in wheel base against the proposed lwb Jimny.
Time to create page: 0.309 seconds
